jon-you forgot the best part
when this mess is cleaned up and new brake shoes & seals are installed the tech also either needs to pack the bearings with grease or pre-load that side of the axle with 90w to make sure there is proper lubrication when you leave the repair shop. As a few of our fellow POGers can attest how about doing all this work and 10 miles down the road have the bearings seize and then need a REALLY expensive tow back to the same shop for a much more difficult and expensive repair.
