3 Attachment(s)
Relays Burning in Dometic Refrig
The this is the second time the propane warning lights has come on and after inspection the relays behind the heat shield are burned and the wires melting. The first time was just prior to POG V and Rick May ordered the replacement relays and installed them. Everything worked fine until last week when I noticed the warning light was on again and after removing the panel found the following results in the photos.
Any suggestions on what the cause might be and possible solutions? Thanks.
