Quote:
Models:
2008 Buick Enclave
2007 GMC Acadia
2007 Saturn OUTLOOK
This bulletin is being revised to add models and revise dinghy towing procedures. Please discard Corporate Bulletin Number 07-00-89-021 (Section 00 - General Information).
The purpose of this bulletin is to inform dealers of special procedures necessary when towing the vehicle behind a recreational vehicle.
Recreational Vehicle Towing (Dinghy Towing)
Important: To avoid battery rundown while towing, remove the 50 amp BATT1 fuse in the UBEC. Refer to the dinghy towing procedure in this bulletin.
Recreational Vehicle Towing Information
Important: Vehicles with a 6-speed automatic transmission that are "dinghy towed" must be started at the beginning of each day and at each fuel stop for a minimum of five minutes.
Recreational vehicle towing means towing the vehicle behind another vehicle -- such as behind a motorhome. The two most common types of recreational vehicle towing are known as "dinghy towing" (towing the vehicle with all four wheels on the ground) and "dolly towing" (towing the vehicle with two wheels on the ground and two wheels up on a device known as a "dolly"). With the proper preparation and equipment, many vehicles can be towed in these ways. Refer to the appropriate model/model year Owner Manual for towing preparation guidelines and dolly and dinghy towing procedures. The Towing Chart below summarizes powertrain combination compatibility with dolly and dinghy towing methods.
2008 Buick Enclave, 2007 GMC Acadia, 2007 Saturn OUTLOOK Recreational Vehicle Towing Chart
Powertrain Combination and Towing Method Rear Wheels on a Tow Dolly Front Wheels on a Tow Dolly All Four Wheels on the Ground (Dinghy)
3.6L V6 (LY7) Engine with Front-Wheel Drive and 6T75 Six-Speed Automatic Transaxle (MY9) No Yes Yes*
3.6L V6 (LY7) Engine with All-Wheel Drive and 6T75 Six-Speed Automatic Transaxle (MH6) No No Yes*
*Notice: If the vehicle is equipped with a 6T75 six-speed automatic transmission, it can be dinghy towed from the front for unlimited miles at 65 mph (105 km/h). To avoid vehicle damage, never exceed 65 mph (105 km/h) while towing Buick Enclave, GMC Acadia and Saturn OUTLOOK vehicles. The repairs would not be covered by the warranty.
Dinghy Towing Procedure
Notice: If you tow your vehicle without performing each of the steps listed under "Dinghy Towing," you could damage the automatic transmission. Be sure to follow all steps of the dinghy towing procedure prior to and after towing your vehicle.
Notice: Don't tow a vehicle with the front drive wheels on the ground if one of the front tires is a compact spare tire. Towing with two different tire sizes on the front of the vehicle can cause severe damage to the transmission.
Important: Buick Enclave, GMC Acadia and Saturn OUTLOOK vehicles may only be dinghy towed from the front, with all four wheels on the ground.
1. Position the vehicle to tow and then secure it.
2. Shift transmission to PARK (P) and turn the ignition to OFF.
3. Set the parking brake.
4. Turn the ignition to ACCESSORY.
5. Shift your transmission to NEUTRAL (N).
6. To prevent your battery from draining while the vehicle is being towed, remove the 50 amp BATT1 fuse in the UBEC, and store in a safe location.
7. Release the parking brake.
Once you have reached your destination, do the following steps:
1. Set the parking brake.
2. Reinstall the BATT1 fuse.
3. Shift the transmission to PARK (P), turn the ignition key to OFF and remove the key from the ignition.
4. Release the parking brake.
I am looking at buying the following Blue Ox Equipment. From what I have read Blue Ox has the best looking Base Plates for the Enclave but what about the tow bar itself? I have read you can get adapters to work with other manufactures tow bars. Is there anything else I might need for installation/operation? I should not need a brakeing systems? What do you guys use to protect the front of your car bra, bar mounted deflector, or both? Any recomondatio0ns on protection for the Buick would be appreciated.
