Help!! Battery/Starting problem
Wow, I didn't think I would ever be here asking this question but here goes: My rig had been sitting for about 45 days, plugged into the shore power when my son heard the 'voice' inside the coach stating that the chassis batteries were low. I discovered the ignition key was in the accessory position. I then tried to start the coach but to no avail. I called my road service. They tried jumping the batteries but that didn't work, either to the Prevost battery studs or directly to the batteries. Without my knowledge he jumped it directly to the starter and had me try it from the cab. It started and I ran the engine for about 1 1/2 hours. When I shut it down it wouldn't restart. Then the voice advised of low batteries and the 'Equalizer' light came on in the dash. I bought a good battery checker and put a load on each of the 4 batteries. After the load was removed the batteries showed about 12V or just a hair less. I charged the batteries all together using the jumper studs until the batteries were fully charged. No luck. Everything was the same as before. The engine will not start from the front or the back and I don't even get a solenoid click. I don't find anything in my manual that shows a reset but I am guessing this may be something simple. I hope so! We are getting temperatures down in the teens so keeping these batteries from freezing is a must. At least for the moment the meter shows that they are fully charged. I hope one of you smart guys out there can offer me some advice. I suppose now would be a good time to apologize for some of the wise-a$$ remarks I made to some of the great POG members!:(:(
