Anyone with links to purchase a replacement fan for the bus air hot air fans? One is working the other is not, this is for the radiator side not producing the cold air.
I am not sure I understand the question ... but if it is Prevost Bus Air, then you should be able to get all of the parts from Prevost.
Thanks Fratto, this is one of the two fans that are in the side bay the point to the ground, I believe to assist with removing hot air for the radiator.
Before you replace the fans have you verified there's power to the fan when needed? Perhaps the second only runs when the coolant temp exceeds a threshold. Perhaps the relay is simply broken or wiggled loose.
But I must admit i'm not familiar with such fans that blow down. A pic would be helpful.
But as Fratto mentioned, I think you first need to determine whether these are Prevost parts or something else. Perhaps the heat exchangers from your generator, which would NOT be a Prevost part.
