Hello ! I would like some recommendations for a Tech that could inspect a bus for me. My largest concern is delamination of the side panels as well as water leaks in general. Any help with this would be appreciated. Thanks in advance.
Depending upon where you are located…would recommend Prevost Nashville. Prevost service centers are the only ones truly capable of performing a pressurized delamination check of XLII Coaches. Other places will walk around and hand “thump” the panels and try to guess whether a particular panel is loose. Also, only Prevost can provide the riveted/seamless repair, if needed.
As for inspection of the Coach itself and the particular converter (i.e., Liberty, Marathon, Millennium, Featherlite, Country Coach, etc.) - we would highly recommend Gil Johnson - one of the principles of POG. Extremely knowledgeable and affordable.
