Specifications for the ideal Bus Barn
Building a new storage barn and would appreciate your input on the ideal configuration. Assuming you had no limitations, i.e. building codes and land area, what would you want to include in your garage?
What is the ideal overall size for just the bus, minimum size? How much clearance around the bus?
How big of door? Would you put doors at both ends if you could?
Ideal ceiling height, for room to work on top of the coach.
What considerations to give to turning radius for pulling on and off the road? My access is off a 50' wide country road through a to-be-installed gate.
What would be helpful to have installed in the garage; power, water, air, heat, etc?
Would you do an internal storage room for items relating to operating the bus? How big? How would you configure the shelving?
Undoubtedly constraints, if none other than costs, will become an issue, but trying to avoid the "damn, I wish I would have put in..." after the building is done.
Thanks for your help.
Chris
