Works on auto start works from gen set will not start or kill inside It is Marathon H345 2001 Danny
Going to have to tell us a little more in detail Danny for us to jump in with our two cents worth of advice:-))
If the generator was started at the generator itself manually, and your coach employs a PLC (programmable logic controller) as Libertys and others are, it may be that the PLC regards this as a fault, since it did not call - was not used to call - for the generator to start, and shuts down the ability to start it normally from inside. This is the case with my Liberty, and in that case (Liberty, 2000) the watchdog timer must be reset. Marathons are sure to be slightly different, I would think, but it may be this is the area to concentrate on.
It will start auto or with inverter but will not start or stop with controls at drivers seat thanks Danny
