Liberty Fresh Water Gauge
I let my fresh water tank run completely empty on a trip a couple of weeks ago. No big deal as we were pulling in at home when it happened and when I parked I flipped the water pump breaker.
Now, the next day after we unloaded the coach and I backed her into the bus barn, I hooked up the hose and started filling the fresh water tank and dumping the waste tank. Standard stuff. The waste tank is always fast and the fresh water takes another ten minuets or so and I watch the gauge so that I don't overfill and spill a bunch of water on the barn floor. This time, the gauge doesn't register the water going into the tank. The gauge just keeps flashing the red empty light even though the tank is in the process of being filled. When the tank is full and a little water starts to spill out of the overflow, I shut the fill valve, unhook the hose and turn the gauges off.
I don't give it much thought, believing that when I turn the gauges back on all will return to normal. No such luck, even with the fresh tank full, the gauge empty lights are still blinking and the levels shows zero.
Any thoughts appreciated. I can call Liberty tomorrow, but I've got some time today to work on the problem and would like to get it fixed.
