Cruise control, Jake brake, and high idle won't work. Any quick suggestions? On the road now.
Thanks, Sandy
Thanks, Sandy
There is a circuit breaker in the electrical bay-steering bay,could also be a relay that should be in that bay also.I think that Prevost should have a listing of each breaker and relay on the door.Hope it is as simple as a tripped breaker.
Jack, Ed has checked the breakers in the front & back. Will check relay now. Thank you.
Sandy
Relay Sandy!
Ed,
I had a similar problem in Dec. 2007. The culprit was a faulty brake light switch; when you are on cruise control and you tap the brake the switch allows the cc to release. I changed the switch ($38) and everything worked again.
Someone's knee (while working on Buzz lights) landed on the module plug in the VIM box. Retainer was broken but plug was intact. Reinserted plug in socket and all was working.
Thank you all.
Sandy & Ed
Youall must be living right! Lucky, Lucky
