Does anyone know where to buy replacement lenses and bulbs (24 volt 10 amps tube type) for the bay lights?
Prevost says they do not carry this style lense any longer. Thye do have the bulbs. 1996 chassis.
Jim,
I don't know how well lighted your bays are, or how effective the positioning of your lights is, but I am contemplating redoing my bay lighting because I block some of the lights with stuff I have in the bay, and other lights are blocked because the converter filled the bay. I would suggest if you need light fixtures or lenses, start from the beginning and replace the whole thing, and if appropriate relocate it to a position that works better.
JIm,
Jon, as always, is right on the light. The bay lights barely do the job. I installed these lights in my closet and they provide a lot of light for not many watts. Very low profile at 1.25". The big question will be if they are available in 24v.
Not cheap as they run about $40 each.
Attachment 2430
the website with more options.
http://www.thinlite.com/prod06.htm
Mke
Try this link this is what I used in our generator bay rebuild. A HUGE improvement.
They can be powered with from 11 to 25 volts.
http://www.westmountainradio.com/PWRbrite.htm
Try Internationl Bus Parts in Florida.
Jim, The way the bulb burnt the lense I would suggest looking for someting that doesn't put out so much heat.
GregM
