Does anyone have a photo of this batteries location? Is this a coin cel battery?
GregM
GregM
Mine are a pair of 12 volt AGM batteries wired for 24 volt-they are 4 inches X 3 1/2 inches X 2 3/4 inches.
I took one to batteries plus and they fixed me right up.
Radio Shack carries several sizes of small batteries. I bought my ZipDee Awning batteries from Radio Shack
My batteries are hidden ,close to my Coach batterries in the middle of bay #2. They are the same size as the zip dee batteies . I ordered from zip dee.
If that is the case mine must be wired to the chassis or house system. Thanks
I found my battery, it is inside the AB unit. The AB rep in my area had the batteries in stock and told me they were around $100, I question this since I had seen online companies selling them for 15 to 30 bucks. I took the battery to Batteries Plus and they took the old battery connecter wires off and put them on a new 3v Lithium battery for $15 total.
While talking to the AB tech I asked about the communications port on the front of the AB PLC and was told that it is used to program the unit and he asked if I had a backup program. Apparently if the you fail to replace a dead backup battery (which is only used to save the program memory if you loose main power) you have to reinstall the program with the backup program or what ever is controlled by the AB is non functional.
How may people out there have a back up program for their AB PLC's? If you have an orphan coach this may be a problem if you don't.
